Blower motor doesn’t blow on high speed? Replaced a/c selector switch, resistor,motor I’m lost any help would be appreciated FYI if I run power straight from battery it will blow on high??
With 12 volts connected directly to the blower motor it will run at it fastest rate as long as the ground is good. You'll want a fuse and a toggle switch in-line with the 12 volts, so that you can disable when not in use.Blower motor doesn’t blow on high speed? Replaced a/c selector switch, resistor,motor I’m lost any help would be appreciated FYI if I run power straight from battery it will blow on high??
I've actually seen that connector unconnected on many G-body's over the years. I don't exactly know why.Take a look at a connection that is on the passenger side close to the front of the engine. If that connection or the wiring has fallen onto the exhaust manifold or headers the red power wires for the fan may be burnt or the connection itself may be fried.
Replaced the relay still not working. It only blows on the 2 medium speeds not low or high?
