looking to get at least the defrost function working in my 80 cutlass and trying to sort out the wiring .if you look at this pic the red wire going to the high speed relay has been cut .Before my engine swap it was this same way and i had a/c and heat on all fan settings. i tried putting 12 volts directly to that red wire but no power to the blower.I did hook up the blower direct and it does work .i must be missing something simple? is it possible the previous owner had it working a different way?
