BMR Suspension Coil-Over Conversion Kit for 78-87 GM G-Body
CCK007
Increase traction, add ride height, and improve suspension geometry adjustability to the rear of your 1978-1987 GM G-Body with a Coil-Over Conversion Kit from BMR Suspension. OE-style lowering springs can drop the vehicle, but do so at the expense of suspension and shock travel. By utilizing a conventional coil-over, the vehicle can ride at a lower ride height, while still retaining full suspension travel. BMR manufactures its Coil-Over Conversion Kits from CNC-laser cut, CNC-formed 1/4-inch steel plate for strength, lightweight, and precise fitment. These mounts add three extra mounting positions for the lower control arms, allowing you to change instant center and anti-squat geometry. Whether you want to aggressively lower your G-Body or you want the added suspension control you get with coil-overs, BMR makes it easy to add coil-overs to the rear of your car. This kit is designed to work with any coil-over with a 1.25-inch wide bushing and ½-inch bolthole. BMR Suspension’s CCK007 Coil Over Conversion Kit is available in black hammertone and red powdercoat for long-lasting good looks. Installation time is 2-3 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Avenue, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
