Body bolt sizes 78 monte
Geo's66
471
104
guys, anyone know the actual size bolts? Can't find a thread and want to buy the grade 8 locally. I believe there are 3 sizes for this car? Thx much
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
I ordered more bolts from McMaster-Carr. M10x1.50, 10.9 hardness, 60mm, 90mm, and 100mm, plus flange nuts for the radiator support. Painted with POR15 for foreverness.
dscn5866-jpg.47122
Geo's66
471
104
perfect, now if I could ask 1 more favor- would you know where each goes into which # positions? thanks very much.. !!!
love the foreverness, great idea!
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Body bolts:
M10 x 1.50, grade 10.9, cap screw, black oxide,
(98093A648) 2 x 60mm (under driver) location 3
(98093A642) 8 x 90mm location 2, 4, 6, 7
(98093A652) 2 x 100mm (radiator support) location 1
Zinc Plated Class10 Steel Flange Nut,
(95003A103) M10X1.5 Thread, 21.8MM Flange Diameter, 10MM hole (radiator support)
Zinc-Plated Steel Oversized Flat Washer,
(91100A170) , M10 Screw Size, 10.5MM ID, 30.0MM OD (for shimming)
Corrosion-Resistant Coated Class 10.9 Steel Flat Washer,
(91455A450) M10 Screw Size (radiator support and shimming)
McMaster-Carr part numbers.
http://www.mcmaster.com
