Well, I am finally in the homestretch, or at least seem to be, for bodywork. I just want to check to see if this sounds right or if I should alter my plans.
Current State
Currently, Most of the spots that need filler are filled, smoothed, sanded to 320 grit, and primed with U-Pol High #5. I still have to do the roof seams, which won't be done until I get the quarter windows out, and there are a few other small dings which still need done, but they will take less than 2 hrs. The parts of the car that are not filled or primed are D/A-ed down to 150 grit.
The Plan
The next thing I have planned after I finish all the filling and priming (with the exception of the roof seams, which won't be done until last) is to D/A to 220, then D/A to 320, then using a 16 inch Dura-Block, block the entire car to 400 grit. After this is done, the rear windows can be taken out, roof seams will be filled, check the windows for fit, and send the car off to paint.
Does this plan sound ok? Should I block the 220 & 320 or will D/A be alright? Will a 16" Block be OK? Any tips? Sorry for all the Qs, this is the first I've ever attempted anything like this.
Current State
The Plan
