Brake booster bad ???
dickeymoore
924
Atlanta,Georgia
I have a 1980 monte carlo daily driver and all of a sudden the brake pedal got hard when driving and I heard a pop sound, is the brake booster done or what i have a vacuum canister also?Thanks
airboatgreg
2,866
3,114
Make sure you have good vacuum to the booster. Possible sludge in carb restricting vacuum supply so see if supply is coming from rear of carb or top of intake
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
if your car stalled after that from a lean condition check the vaccum line to the booster.
melloelky
4,155
9,545
mass
with the car running pull the vac hose off the booster to see if it is pulling vacuum.
565bbchevy
9,611
12,668
Michigan
Maybe the check valve got stuck open or failed.
moby92
Mar 27, 2017
50
30
This seems what is happening to buddy's car. We'll just finish installing the parts from 4Wheelonline onto the truck and we'll check it out.
