Bringin this one back. What was the out come? I own a 87 Regal Limited, has the 307 (for now) w/cruise control, and was almost rear ended the other day. Turns out my brake lights have quit. I know they were working earlier in the morning as it is 4 am when I leave to go to work, and the six or so brake lights really light anything behind me
so I have tried a new switch with no luck, I did some multimeter testing and I am pretty sure the brake light switch is fine, I tested the one from Autozone, the one that I thought was bad, and the one that is similar, that I pulled out of my 81 bu' wagon. They all were zero's ohms when depressed, or vise versa. I also checked the wires on the column, mine don't seem to be pulled out or any thing either. I was wondering if any one has a good write up, or a picture or two of the "turn signal switch" I do have power at the orange wire, and have jumped to the white wire with no luck. I guess I am confussed as to what is being said is the turn signal switch. Is it the whole combo switch? (the one that does your blinkers, wipers, and cruise?)
Thanks, hope that I can figure this out soon, It is serving daily driver duties right now, and soon will be the wagons replacement. The wagon was my street strip, freeway on ramp bad boy, but I have owned it for so many motors, trannys, rear diffs, and other Hi po parts, that when the latest engine had a minor hicup, I figured I would start over with a Regal. I almost got a Regal before the bu', and now 12 years latter, its time to swap out.
