Brake up grade options guys, having trouble getting stopped.
lavoy1
n00b
Jul 14, 2014
hey guys im new here let me explain my issue. i recently bought a 78 chevy malibu roller to convert into a street strip daily driver toy. here is what i know the front brakes are hawk hps pads for a 78 malibu, the rotors are cross drilled and slotted. the calipers are oem. the master cylinder is of unknown origin but it is converted to manual using a s10 manual brake plate on the fire wall. the rear end is a 69 chevelle 12 bolt with 9.5 inch drums. ok here is my issue the car is trapping around 143mph in the 1/4 and it uses all my strength to get stopped in time for the last return road. also the pedal is very spongy even though we bled and bled and even vacuum pumped them. i cant afford anything ridiculous im not wealthy so looking for affordable upgrades. i found this option for the rear http://www.ebay.com/itm/68-69-70-71-72- ... 0561539107 but dont know what to do for the master cyl or front brakes. please help guys its getting to the point im clenching my cheeks after a pass and im second in points for the season so far and dont wanna miss any races due to being un able to stop safely. thanks.
clean8485
2,862
2,154
Ontario, Canada
Re: Brake up grade options guys, having trouble getting stop
Welcome to the site. There are many many threads and posts on this site and other G body sites regarding brake upgrades. I'm sure that if you were to do a search either here, or on some of the other sites (MalibuRacing.com MonteCarloSS.com GBody Central.com, or any of the turbo Buick sites), you should be able to find more than enough info to give you options for your situation. Hope this helps. Good luck.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I'd get rid of the cross drilled rotors cause there is no gas buildup in pads these days and the holes only reduce the surface contact reducing the effectiveness of the braking. I would also switch the pads to yellow EBC pads. Also without knowing the size of the bore in the master can't say if that is the correct one to use for manual brakes
lavoy1
n00b
Jul 14, 2014
how can i get you the info you need on the bore? i see no numbers on it. would a pic help?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
picture would not help, different bores come in the same housing. Only way for you to find out is to take the mater apart and measure. Personally I would go with a master that you know is the one you want. Masters are not that expensive.
lavoy1
n00b
Jul 14, 2014
knowing what you know about my set up what master should i go order? keep in mind i am looking at this kit for the rear http://www.ebay.com/itm/68-69-70-71-72- ... 0561539107
