Haven't posted in a few years, car's been in storage.
Problem initially started with a leak, I eliminated the leak, then began bleeding the brakes and noticed the rears are not engaging, and have gone unnoticed for quite some time. Reset the rear shoes, tried bleeding again, no bleeding from the rear.
I suspected the very old proportioning valve went bad, so I removed it, T'd the front lines together, and installed a Summit adjustable proportioning valve on the rear line. Then tried bleeding, same issue again. Some fluid drips out the rear, but no pressure loss from rear bleeder screw when bleeding.
Then opened all lines, cleaned or replaced bad ones, and tried again, same issue again.When bleeding, fluid only drips out slowly from rear, but no pressure loss from rear bleeder screw when bleeding. Brake pedal feels clunky on first half of travel, then firm on second half.
So then suspected bad master cylinder, and replaced with new one. Bench bleed use back-bleed method, installed on car, then tried again, same issue again. Now fluid squirts out from rear, but still no pressure loss felt on pedals. Brake pedal travel feels smoother with new master cylinder, but still no pressure loss felt when bleeding rears, front bleeding works fine.
In all attempts, fronts bleed okay and hold pressure. I drove car and test brakes with only front system, it works fine, but still no rear brakes engaged. If wheel cylinder is clogged, why does fluid squirt out the rear bleeder? If fluid squirts out rear bleeder, why no pressure loss on brake pedal?
What is going on?
Thanks for reading!
What is going on?
Thanks for reading!
