Bucket seats
Hubb79
Hubb79
25
Does anyone know where to get a release spring that connects to both tracks for bucket seats?
P
PBGBodyFan
251
Wisconsin
Might have to compare the bucket and split bench ones, have a feeling GM kept that part the same. I know when I needed one for a split bench track one from a b-body was identical in style/length. Other platforms might interchange as well (f-bodies & j-bodies?).
S
slow 442
44
11377
Bend one up from a clothes hanger until you find a suitable replacement.
Reactions: wskirvin
AZRegal
AZRegal
150
Mesa AZ
They are different lengths for the 60/40 tracks and the bucket tracks. The bucket seat ones are shorter. So you can take one off the 60/40 seats and rebend one end the make fit the bucket tracks. It is just a piece of metal wire. You can make them pretty easy. I doubt you're doing a Concours d' Elegance level resto on your Gbody so just make one or two. I have used brake cable from a bicycle before and crimped the ends and it worked fine.
AZRegal
AZRegal
150
Mesa AZ
Using my "special" tape measure you can see the cross over cable on the 60/40 seat track is about 1 foot long.
On the bucket seat track you can see the cross over cable is not quite 1 foot.
So find some from the 60/40 seats and cut them down.
JAMCAR223
JAMCAR223
776
Houston, TX.
With the mounting pattern on most GM mid size bucket seats being the same, I feel that G Body, F Body, S Series, Astro, etc would be the same.
This would work also. I have done it. Some aftermarket seat tracks use this method
The bicycle brake cable would work fine also.
Thread starter Similar threads Forum Replies Date
dagrams G-Body Build Threads 1
