Write it up! Let's see all the hard work!
Well first off I started with suspension in the spring. I put new front coil springs about $70. Then I found an engine from my dads friend out of a 93
caprice complete with whole wiring harness (key to have). Then I kind of just planned out everything including the swap and all that. I got an electric fuel pump and a new radiator. The hardest thing for me was finding the right fan shroud that wasn't on eBay for $200. Also bought myself a chilton book for both the cutlass and
caprice to make wiring easier. Now the easy part is the swap. Took maybe 2 days. The new motor mounts only use 3 holes (they make adapter mounts I believe but this was easier for me). The bottom left hangs off the front towards the front of the car and the others are normal. Then it's just a matter of dropping the 350 in and there you have it. I did find out that the stock exhaust on the cutlass doesn't quite match the crossover from the manifold on the 350 for me so I had a shop do some fabricating. Um some other key factors are fuel lines. The fuel lines on the cutlass were on the drivers side and go to a mechanical pump mounted on the engine. So I opted to find some old fuel lines from a pickup that had a throttle body and get the lines from that. Worked out great as these were braided and not steel so they didn't have a definite bend to them. The wiring was the worst part. That took a few weeks figuring out where everything went and cutting wires to work for the fuel pump, distributor, ecm power and alternator. Long story short on the wiring part is having the chilton book helped a lot and plus having the whole wiring harness from the
caprice also. Last but not least is making everything look nice. I had to cut a hole in the passenger floor pan to feed the ecm wires through as they would not fit in the existing cutlass hole. I did all of that so I could put the ecm back where it was supposed to be. After working all summer on this project it was finished and looks pretty much factory so I'm proud!
