Buick GNx sending unit and pump
theIrishman
Has anyone had success with using a Buick Grand National fuel tank sending unit and pump (or aftermarket high volume/pressure pump) in a 1978 and up Malibu fuel tank, Ls 5.3?
Or has anyone modified an original Malibu sending unit to work with an in-tank electric pump, and added a return line?
Pronto-
Dec 4, 2014
84
78
If your going FI then you want the tank for a Turbo Buick with the dog dish and splash guard so you don't end up sucking air on a hard corner or launch.
UNGN
3,048
3,264
Southlake, TX
A GN tank has a sheet metal wall that runs down the middle:
Doesn't do much for corners, but makes sure the pump doesn't suck air when accelerating. Carbs have bowls and don't have to worry about a couple seconds of air..
MC96
458
492
Ive been told the FI sender in a non efi tank isnt a big deal in autocross, as long as you have it above 1/4 tank.
I would imagine you wouldnt see many issues street driving it
20Grand
Mar 16, 2018
59
10
I’m using a fuel tank from a Monte, about the same as your GI, and just drove it across the country. I’m using an AC Delco pump tho.
20Grand
Mar 16, 2018
59
10
But, I think you can get away with the stock tank with upgraded pump and sending unit. My mechanic that builds LS swaps also confirmed, but wanted to be safe on long distance trips. If you do the swap, order without fuel tank neck and order YOUR fuel neck and install.
