Buick Regal Somerset part out
Trader history for buickregal (0)
B
buickregal
22
RI
Parting out a '80 regal somerset. Located in RI. Ask for more pics of anything specific. Prices: make a fair offer on anything.
seats
upper door panels
lower door panels
arm rests
all interior trim
wire hub caps with center caps
hub cap brackets
blue hub cap key and 4 bolts
lower door rubbers
side mirrors
a/c heater box
wiper motor
3.8 / any motor parts
th200 (?)
window glass (windshield, rear, both sides rear, both sides door)
chrome trim / badging
dashboard
steering column
right side tail light
left side tail light (broken)
corner lights
nose, grill, and brackets
exhaust
fuel tank
14" steel wheels with cracked tires (they hold air)
etc. - anything else, just ask
Not for sale: fenders, doors, hood, trunk, rear end, driveshaft, bumpers
Sold:
linkage from column to trans
speedometer cable
rear deck carpet piece
headlight switch
regal/limited/somerset/buick badges
hub cap center caps
hood/trunk ornaments
silver dash bezel, gauge surround, radio plate, and silver steering wheel center cover
radio
sending unit
IMG_20200524_143342_639.jpg 20200524_133823.jpg 20200524_180128.jpg 20200524_165244.jpg 20200524_134056.jpg 20200524_133852.jpg 20200524_164127.jpg 20200524_164425.jpg 20200524_165019.jpg 20200524_163724.jpg 20200524_163653.jpg 20200524_163708.jpg 20200524_163755.jpg 20200524_163622.jpg 20200524_170511.jpg 20200524_170520.jpg
81Regal
1,413
83
Terril Iowa
How much for the 3 silver bezels on the dash? BTW that is an 80 not 81.
B
buickregal
22
RI
My bad, thought it was an '81, how can you tell? The one on the left has 4 holes drilled in it. Here are some better pics. Literally just make an offer and they're yours. Whatever you think is fair, or 70% of whatever you think is fair, or whatever. Plus shipping.
MrSony
MrSony
5,654
Des Moines, Iowa
78-80 are stubby like that and are technically "A" bodies. 81-88 are bigger overall and are G bodies, but the 78-80 cars have way more in common mechanically with the 65-77 a bodies to they get lumped into g body stuff.
This is an 81 regal, but 81-83 look like this. externally 84-87 don't have the kickup on the top of the grille, different headlight bezels, and have the rectangle black/white sweep speedometer, and the taillights with the trim down the center lengthways.
pagrunt
pagrunt
5,711
Elderton, Pa
The main difference between the '78-'80 & '81-87 is the exterior sheet metal with certain parts made to replace one that had to be updated to fit/match the refresh. There is a limited about of interchangeable parts between the '64-'67 1st gen, '68-'72 2nd gen, '73-'77 3rd gen with the '78-'88 4th gen A/G cars. Our generation was A's for '78-'81 then swapped to G to make way for incoming replacement FWD platform which became the new A body. If it wasn't for the attempt to convert the US to the metric system in the mid/late '70's & size reduction in the name of fuel economy our cars would of had more interchangeable parts. A little unkown fact was in early '82 model year paint info PPG listed the RWD's as A's & the FWD's as G's. Could it been a print error, missunderstood info exchange between GM & PPG, or GM decided to swap platform names late in the '82 pre-production as they were planning to end the RWD platform but it's a guessing game at this point.
