Buzzing noise killing my battery overnight when car off . Somebody told me they have a white box under dash that might be bad I’m clueless on what the part called .i changed my door pins the light switch . Any help
Yea it’s killing my batteryKeeping an eye on this. I have a buzzing noise coming from behind the cluster area, but only when car is running. I deal with it because the exhaust drowns it out haha.
Figure out what’s causing the buzzing noisepull one fuse at a time to see when the buzzing stops.....
That seems harder than just cutting wiresThat's the key buzzer. You should be able to disconnect it without cutting anything. The switch that activates it is in the steering column, inboard of the ignition lock cylinder.
Also I didn’t notice where I can disconnect it from ?That's the key buzzer. You should be able to disconnect it without cutting anything. The switch that activates it is in the steering column, inboard of the ignition lock cylinder.
