SOLD C219-U Viking Coil-over Double Adjustable Shocks
Trader history (0)
Chevyman540
44
Viking Double adjustable coil-over shocks These were from UMI kit 3064xxx for a G-body Monte Carlo and I lowered the car too far to use. Part# C219U TBAR/BEARING EYE/BEARING(W) Ride hgt-16 1/2-18 ¼ comp. height 13.50 ext. height 21.25 shock stroke 7.75 Uses 12" or 14" springs (not included) • Height Range is 1” lowering to 2” above stock (provides clearance for drag slicks). • Bolt in design mounts to factory rear end housings. • Included Viking Warrior double adjustable shocks offer 19 compression and 19 rebound adjustments. • designed for height range of up to 1” lowering and 2” above stock $ 400.00 Shipping included lower 48 states or local pickup Laporte, IN
Thanks for looking.
Bill (Chevyman540)
Text-219-363-9620
drb930
48
8
Los Angeles
Could these be used with stock springs?
I have bags in my springs for hauling/towing.
How do they compare to VariShocks?
Thanks,
Dave
bruisedbanana79
242
If you haven't bought new shocks yet I have a brand new set of the C209's that I want to trade for the C219. I can't lower my car 2" without the rear calipers hitting the frame.
Chevyman540
Thread starter
Jan 11, 2016
44
Thanks,
Dave
I suppose you can use them that way. They do bolt in at the same place as the regular shocks at the top.
As far as the varishocks not sure. These are double adjustable, 19 clicks on compression and rebound.
Chevyman540
Thread starter
Jan 11, 2016
44
Those are the shocks I bought already. It's been 2 years since I finished the car and these have been in the cabinet.
