C5 Corvette Front Brakes with Blazer Spindles
Built6spdMCSS
5,804
9,713
Florida Beach
Those that have front Blazer Spindles and have upgraded to the C5 Corvette front disc setup, what conversion brackets did you use?
I have found a couple, just curious.
  • Friendly
oldsmobile joe
2,067
3,053
mpls
i have kore3 brackets. fantastic quality.
Firetruck1
193
300
Id like to do this swap and still be able to use my 16 inch ZQ8 wheel and 15x4 Telestar wheels at the track.
UNGN
3,048
3,264
Southlake, TX
That probably won't work.
16" wheels definitely will not work with C5 brakes (13"). 17" minimum. Some 16" wheels will rub LS1 brakes (12")
81cutlass
4,647
13,561
Western MN
An ls1 4th gen camaro/firebird will clear most 16" wheels and some 15" wheels. The only main difference between a 4th gen LS caliper and a C5 caliper is that the C5 caliper is a bit wider to accept a wider rotor, and the C5 caliper has the ribs cast longer toward the wheel. Unless you are running a sticky 245+ width front tire and are seriously hot lapping the car at a track and are worried about heat soak, the LS caliper will probably be fine. My LS setup is enough to lock the front tires up at 50mph with a 275 older BFG tire. Im sure it wouldnt do it time after time at a road course, or with a sticky more track oriented tire, but the LS setup is very competent.
This is a 15x7 pontiac rally with a 2" spacer. A 1" spacer would work. The big problem with LS calipers is the caliper sits quite far out to the wheel mount surface. The wheel center runs into the caliper before the wheel itself hits the ribs cast in the caliper.
A 15x4 skinny should fit with that 1" spacer.
EsgITo34jTagQhlDTgLHYxnw7aTmVNpFHbmP4Wy1gqnEWJ1bxnrkB_mdJS2HvqK3wGGeqy2zSS7kLwPaCo-87x9rXu8U54diZuSS7Paz5yagasGcYhwFDL2Mb9kMqWBaHpOWjeoNzZBTbOzCNyj-bkenNUkRe_422cNfV_20fS_LppPGWwGCUEmXc-FbAsUxDV6ODhXXFU_BaxYd337QlYeiqfWP4TR7g4IehLh5HFJpjwMpi-JnVkhEBHXxA2hvbQLCHR1HJYj3Qi_pMFvZqBn_TfjvZHj8hunHg20XQBF-JxMj63gxsyu6ZBDafKM4yUOGR-qrfVQHlLitbPtPdKIhP2f9ON5PY4LvI_HayL7Ka_Ndd58Xvk_t5BAKKzh2TuGXkVb49otGcW3utgn0pmCjFofLU4e7rGL-oY2DLtUCcf36ArIYpLpWHJ-gWIWl4yKSpgjR_DzMVkRyO7dnksRxNUwWQoE4zTd-XVLSNcpRYWP_cmQJ3DuURVLotZH4aD76RFMryQvUNY0SObHjXd4C_JZqvQmHXWzebvLT8OeWNkc60m3nC77eZe0AjLa4qxjyQBwNzh6SJjLaJPv7qYvtVFB7H3b65K5ZVOM=w708-h943-no
  • Disagree
UNGN
3,048
3,264
Southlake, TX
Any wheel will fit any brake if you space them out like a Mexican Pickup truck.
81cutlass
4,647
13,561
Western MN
Yeah, I forgot to put the important part, I intend to run the 15x6 with a 195 tire for drag use. It's a 4" BS wheel. With a 1" spacer it's 3" bs so it's ok. 0.5" bs farther out so the scrub radius didn't change much from 15x7 4" bs no spacer. The 2" spacer was left over from when I run my c5 wheels which makes them 4.5 bs like they should be for a non f body/c5. I don't intend to run a 2" spacer at all with a 15" only the c5 wheel.
4th gens have to grind the caliper to clear a non 4th gen offset 15x4. Since g bodies wheel mount flange to fender lip is roughly 2" more than a f body all a 1" spacer does is mess up scrub radius which nobody cares about on a 15x4. The tire still sits inside the fender lip fine.
Geezy24
Nov 18, 2017
60
147
33
Kore 3 although there is a guy on ebay that sells brackets that are just a good as kore 3 for a bit less. 125 I believe free shipping
