C5 Z06 FRONT BRAKE SWAP
Built6spdMCSS
Built6spdMCSS
215
256
#1
Today I installed C5 Z06 front brakes on my SS. I had been piecing this together over the last couple weeks.
Parts breakdown:
ZQ8 Spindle Adapter Brackets: $125 (eBay, link constantly changes, have to search ZQ8 C5 Brake Adapters)
C5 Z06 Calipers, Brackets, Lines: $180 (VetteVillians)
Z06 Rotors & Ceramic Pads: $135 (I pulled the ones that were on my C5 Z06 and put drilled & slotted on it)
Getting Z06 Rotors turned: $20
Disc/Disc Brass Combination Valve: $50 ( http://www.highwaystars.net/brake-p...places-gm-1257189-4-wheel-disc-brake-systems/ )
All this here is $510, which isn't too bad.
EDIT: Sold the Blazer stuff in the front that I had on it for $60, so $450 invested here.
The first thing I had done was install the Disc/Disc Valve, pretty much a direct swap.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FDEWEIXq.jpg&hash=bb69b1115350008f4ff43df76c233787
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FMP3BtOF.jpg&hash=a89f18e875ca7291ce6173b0d578c721
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FBFnuDOK.jpg&hash=6ae7a9b65caee83a29aaee3eda26d284
Parts layout of the rest of the swap
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F1M3NuWc.jpg&hash=f72dbd46bc10924593d52e82a8f136b7
This is a size comparison of the Rotors
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FVhwxs8D.jpg&hash=93d1bd5e277e1937c8e0fe950c150171
Since I had the newer Blazer Brakes on the front, I already had the ZQ8 Spindles. I bought the adapter kit for that which came with some instructions and all the needed hardware. It was pretty straightforward. The Spindle required clearancing with a grinder
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F8OIvOqH.jpg&hash=da5ba1f9735d4fc88544ddfaf0cd236b
Test fitting the adapter bracket. I had painted this, it comes raw steel.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FhuaKlve.jpg&hash=0cd39d9814c6995669c313a9833948a5
Once that was good I test fitted the Z06 Caliper Brackets
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FBXDDpgO.jpg&hash=20d2114e726ff74520032f0d03274a99
Z06 Calipers and Ceramic Pads went on
proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fjbl31tR.jpg&hash=e53633603e484deeafa65fb51526044e
Then the lines installed. I had to install new flare nuts, the ones on the car were bonded to the other lines pretty much. I used the C5 Z06 lines, the bottom required a little bending to clear properly.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F7QBZr7K.jpg&hash=b2414640e815db6cf6865f46074657ee
They fill up the wheel nicely. Took it on a very short test drive because of the weather and the difference was very noticeable. Once the pads seat in it will be nice.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FC3AlV6q.jpg&hash=7ab8622f418b732f5bff78d2f646bbbf
Rear Calipers were painted to match, the rear has LT1 Fbody Disc Brakes.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FTvGHRdb.jpg&hash=f912380944eea24c8b3bf38ca4341369
G
Gremlinsteve
237
224
#2
Super
What size wheel
I'm going to try to use my 17 inch ramblers
I'll try test fitting first of course
I have 640 all in and that includes a new master cyl and new rotors
Built6spdMCSS
Built6spdMCSS
215
256
#3
17's here, you can see it on the tire size haha. They are the minimum size to use for C5 Brakes.
G
Gremlinsteve
237
224
#4
Cool
Firetruck1
Firetruck1
Nov 1, 2017
68
108
#5
How did the conversion effect from the blazer brakes to this effect the balance of hard braking? Also, do you still use the stock master cylinder? Nice build!
Built6spdMCSS
Built6spdMCSS
215
256
#6
Master is stock, front bias is still 70%, not sure what you are getting at.
Griffin84ss
Griffin84ss
170
123
Georgetown, ky
#7
Nice conversion and wheel setup you have.!!! Hopefully I can get my 84ss set up like that here soon.!
Firetruck1
Firetruck1
Nov 1, 2017
68
108
#8
Thank you, do the fronts lock up sooner with the larger front brakes then they did with the blazer parts? Have you considered a adjustable proportioning valve?
Built6spdMCSS
Built6spdMCSS
215
256
#9
No need for the prop valve, I'm going to let common sense answer your other question..if you have it.
UNGN
UNGN
2,595
1,971
Southlake, TX
#10
Ideally, the fronts should always lock up before the rears, unless you want to die the next time it rains.
Larger rotors are easier to modulate under hard braking, so if the fronts lock, reduce braking pessure slightly and they will unlock. If the rears lock you can be spinning out of control before you reduce braking pressure.
Similar threads
