Cam advice
L67ss
1,350
420
Recommendation on cam? Will be a 350 with 10.5:1ish compression with 58 cc chambers, th350, 9" with 3.50:1 gears, and a gutted hoodless car. Looking for off the line to midrange power with some top end. Tq converter hasn't been picked yet so that can wait on cam selection.
L67ss
1,350
420
Forgot to mention that while I'll be starting with a q jet/dual plane combo I'll be planning on a tunnel ram
MrSony
6,826
6,728
Des Moines, Iowa
Not too much of a a chevy guy, but I think a standard warmed over small block GM cam is the 268 line from COMP. I'd start there and go up. Comp has that camquest thing you can download (you have to sign up for it, just put a bunch of bogus info on it, but your real email so you can get it) and it will give you a long list of cams for your motor.
http://www.camquest.com/
MrSony
6,826
6,728
Des Moines, Iowa
If that don't work just download it from the site.
Bar50
1,180
871
Tulsa, OK
Depends on what the plan is.
270 cams usually run up to 5000 or 5500
280 cams usually run up to 6000
290 cams can make it up past that
With 10.5 compressionyou can get away with the higher duration cam like a 280 or 290. You might consider getting the head gasket GM used with the 58cc -113 Fast Burn heads to get to 64cc to be a little forgiving with pump gas.
L67ss
1,350
420
If things go right I'll be able to run it on race gas with as few miles as it will be driven if my connection goes through
383_GrandPrix
678
1,311
Quebec, Canada
10.5:1 compression is fine on pump gas if your quench height is between .030" and .050" and you use a colder plug. Aluminum heads help as well.
Canon_Mutant
1,159
1,420
Sorry if I missed it but is there any port and valve train work done on the heads? One mistake I see quite a few people make is going WAY to much cam on an engine that really cannot use it all [I even admit doing this back in H/S], of course it sounds wicked as hell, but is doggy down low, really starts to take off through the midrange, but then falls on its face because there is such a flow limitation through the heads, intake, and/or lack of carb, etc. Also, really good hardened roller rockers, hardened push rods, high quality lifters, springs, seals are all a part of the equation for the higher lift and duration cams and you want at least 110 lobe separation on the street and don't be at all afraid of 112.
Case in point, I started on my 442 big block build with a Mondello Twister JM-22-25-10 per their recommendation which is a 230/236 @ .050 274/280 advertised, .512/.523 Lift, 110 LS cam in an otherwise relatively mild 10:1 Olds Big Block with mildly ported Edelbrock heads, Performer intake, but only 750cfm on top and just W/Z exhaust manifolds [hate headers] into 2 1/2" dual. I found this cam to be low end lacking, pulled like a futher mucker from 2500 to about 5000 where it REALLY needed more carb and headers. Plus I also was wanting this to work with the factory CCC QJ and the ECM which had issues with this cam.
I changed to a JM-20-22 which is only a 224/234 @ .050, .496/.520 Lift, 112 LS and the thing is just fuel injection snappy, way more torque than I can possibly hook up with the factory suspension/wheels/tires [ALL changing as we speak], amazing power again up to about 5000rpm where the carb and no headers start to be problematic but I am grabbing the next gear at 5200 so right back into the meat. I am only running a 2400rpm HD TC into a heavily beefed 200-4R and 3.73s out back.
The nice thing is that the way the block was set up plus all forged and balanced rotating assembly combined with the way the heads were done will safely take this engine to 6000rpm easily and will flow enough to take this car to 550-600HP by preferably going to fuel injection, headers, and then more cam. So, if I find this thing actually does perform well enough auto-x and on the track to get the bug, I can make those changes without starting from scratch.
Given what you say you are looking for on a small block, I think something in the 215-225 @ .050 265-275 advertised, with .470-.480 lift and at least 110 LS [I would go 112] would get you some rumble at idle but with plenty of vacuum, very streetable, and the very snappy response you are looking for per your stated rpm range.
Hope this is helpful . . .
383_GrandPrix
678
1,311
Quebec, Canada
This is the cam that I'll be running in my set up; http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=159&sb=0
I'm running a 383 stroker with 10:1 compression, aluminum heads with 70cc combustion chambers, 1.6:1 full roller rockers, 4.10 gears, 2500 stall converter
Also, knowing more about those Heads would be helpful:
Intake valve dia.
Flow bench numbers
Maximum lift
Do you have springs to accept a roller cam, etc.
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,177
Upstate NY
Looks like you're looking for mostly strip/hot street use build with limited daily driving. Correct me if I've misinterpreted.
Pick your cam based on your RPM range - Bar50's recommendations are very good. You mentioned you want it to get off the line and have decent midrange power - that request is handled completely by the torque converter. For example, if you pick the 280 cam that wants to run from low to mid 3's to 6000 rpm's (maybe a little more), then grab a 3000 stall converter that is built to flash stall to 3500-3700 rpms. In a nutshell, more cam means more stall, and don't get mislead into worrying about converter slip generating excess transmission fluid heat unless your buying a low budget off the shelf 12" converter. A good converter made by a reputable manufacturer will not have this issue. Of course a decent transmission cooler is always required - I recommend Hayden (can be bought at Advanced Auto for less than $70.)
Good luck
