Cam break in oil ?
Doug213xrj
1,529
131
West Michigan
Hey, I plan on breaking in a Comp Cam with my favorite 10W30 Quaker state Motor oil with a bottle of Comp Cams break in additive. Is this ok ?
Thanks Doug
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
Comp Cams break in oil or Joe Gibbs Driven
Not additives
Quaker State is one of the worst oils you can put in an engine along with Pennzoil
Reactions: 4 users
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,214
I've run a bunch of stuff through my Olds. Brad-Penn is the most stable on the mechanical pressure gauge that I've found. I went roller, so I'm not up on its ZDDP content. I do know that Valvoline VR1 and Lucas Hot Rod claim to have enough for flat tappet cams. Run of the mill crap off the Walmart shelf ain't gonna cut it.
Gonzo1970
898
1,302
With a new cam, you just need to remember these three words:
Zinc, Zinc, and Zinc.
-Gonz
Kennybill
286
401
Braceville, Ohio
If it's an Oldsmobile engine, no matter what oil you use you'll wipe every lobe off it! :LOL: Seriously, start up is the one time you want all your "ducks" in a row. BradPenn (Kendall GTX) is good stuff as are the others named. Hopefully you have a break in stand. Have cooling fans, fire extinguisher, good battery, go over all lines plus a Helper. Good luck.
