Can you install Comp-Cams 268 Hydralic Flat Tappet in a bone stock Buick 350 engine? If not whats the next best cam that I can install ? Note(8.5:1 compression,rocker ratio 1.55:1 ,.381/398 lift,duration 282-304 ,intake 1.88 in.bore & 3.85 stroke)
alrobjr said:Hey Bubba or Phoenyx did you'll use the stock springs or do I have to order some to go with the cam ?
