Camshaft Finally Pulled !!
Tynan918
1,136
249
carnutjw
624
1,469
DRIVEN
8,074
14,533
*CENSORED*
Any oldtimer mechanic will agree that race engines order cams from the bottom of the page.
SSMonteMan
111
225
Yup. Sure looks like you need an engine. Several lobes nearly gone. That cam bearing looks... not so good.
If you're dead set on replacing the cam and keeping this engine... I would recommend the Summit 1102 cam. I just put it in the 305 I overhauled for my El Camino. It's a good, strong cam, and much less expensive than that comp cams one you linked. Get a set of their lifters, part number SUM-HT817, you'll need 16, and re-use your timing set, since you recently replaced it. That's about half the cost of the comp cam set you posted.
