So maybe i can kill two birds with one stone. So i am running 3" stainless steel process pipe for exhaust. Do you think that if i modify my exhaust from a H pipe to a X pipe, that it will be strong enough to catch the front of the drive shaft if the u joint lets loose? In current form it is in front of the drive shaft but if i moved it back do you think tech would let it slide at the drag strip?
