Can i change a front panel of a 79 malibu with a 82 el camino
Can i change a 79 malibu front with a 82 elcamino
  • Body
    Votes: 0 0.0%
  • Trim
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
4
Can i change a 79 Malibu front with a 82 EL camino front having issues finding the head light bezels for 79 only the right side
85ss/85gn
284
252
beaver dam,wi
Fenders are different for 82-87
9,154
15,318
You can put '82 up header panels on '78-'81 fenders but you can not put '78-'81 header panels on '82 up fenders because they don't have the "pocket" for the older headers side marker lights. Another note is the '82 up rad supports have a bigger opening in the area behind the headlights. Not sure if it was cause of the new header or another G body need that change.
zdeckich
460
346
Fort Worth, TX
Where you located? I have a 80/81 header panel on my 78 malibu and would like to do a 78/79 header panel.
12,174
9,774
That would be great if you guys can work out a trade.
Lima, the only other thing you'd need for the quad headlight header panel conversion, would be the wiring harness...or you can modify the one you have by adding additional sockets, etc.
Pagrunt pretty much summed it up in a nutshell. The radiator support can be enlarged to accept the quad headlight configuration. So, no need to replace that, unless yours is rusty.
