Sorry if I over explain my situation.
I've been in the process of putting my front suspension back into the car.
I already fully installed the drivers side, except for fully threading on the lower A arm nuts.
I was doing the same on the passenger side and decided to start tightening the nuts.
I had obtained new Genuine GM short bolts, but after searching high & low, I could not find the long ones in Genuine GM. So I cleaned up the long ones from 1986 with a wire brush. I can't remember if I used a die to chase the threads too.
On the new short bolts the nuts started off tight and stayed that way till somewhat snug to frame. With the old long bolts and new nuts, there was only tightness for a few turns.
I removed passenger side long bolt and measured threads with a caliper. The 1st few threads measured 11.67mm and further in measured 11.47mm.
I think too much of the threads rusted away.
So is there a way to remove the drivers side long bolt WITHOUT undoing a ball joint nut & removing spring ?
Getting the spring in, even with the compressor tool was a pain in the *ss. I still have to deal with it on the passenger side, once I buy 2 new bolts that I located.
