Chevyman85 said:Oh yeah! Anythings possible! I've seen it done before. Do you already have a 455? You'll also need to replace the entire drivetrain, a big block will put out some serious torque. And don't forget the front suspension, those 455's weight a lot more than a SBO. Good luck man!
Chevyman85 said:I was under the impression that big blocks weighed in around 200 lbs heavier than small blocks. I know that can be cut down w/ aluminum intake and heads. Also the exhaust is an issue. Clearance becomes a problem with the frame, esp. on the passenger side. I barely make it with my SBC heads.
creepin cutty said:smog, no they did away with that....
do i need a buick v6 motor mounts?
but the frame mounts?? what are frame mounts??lol
