I'm mounting SSII 15X7 inch wheels on my 1979 which came with 14X6 wheels. The inside edge of the rim along with the wheel weight is
hitting the tie rod end.
Can someone recommend a spacer of 1/4 inch that I can install on the front hub that will push the rim away enough to allow me to bolt the rim on.????
If you know of one that will positively fit can you kindly place a link.
Thank you. AZ
Thank you. AZ
