Can someone verify proper screw please
mc1984ss
296
243
I was hoping someone could please verify the proper screws for this location of my dash bezel. There is one on each side pointing up. How long is the screw and does it have the cone shaped washer on it? Thank you in advance!
79 USA 1
1,065
2,039
Cheektowaga, New York
It should be the same screws used across the lower 4 positions of the dash bezel. Short with the captured washer.
blk7gxn
1,390
1,886
IF my memory serves me correctly, Yes, washer should be attached to the screw and are around an inch long :)
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I wouldn't go with an 1" screw, there isn't much room before the top pf the dash
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I am not sure what the correct screw is but on my GP the holes in the dash would not hold a #10 screw so I filled the holes with hot glue and once the glue hardened I used #10 3/4" trim screws.
