Can someone verify this before i order
Bri guy
845
225
Will this work for a 70s 403? Need to move the alternator to whwre the ac was for an even tension on the pump
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
All Olds small blocks are the same physical dimensions, so yes, it will fit a 403 if it actually fits Olds small blocks. Now, as far as doing what you want....? That's a $113 gamble you'll have to take, unless you find someone that has used it. Looks like a nice piece, though.
Bri guy
845
225
Ok. Looks like it should work. Hopefully this makes the belt squeal disappear if i put the the alt on the other side. Thank you
popeye1978
235
208
Have a similar kit on the Mustang -- the expanding rod lets you easily adjust belt tension, much better than loosening the adjustment bolt, pushing/pulling on the alternator with one hand and then trying to hold the tension while tightening the adjustment bolt, measuring belt tension and finding you still don't have the proper tension, and then repeat
wonderboy24
1,322
1,300
Davenport, Iowa
i am curious my self. i like the looks of it. right now i have the stock bracket and mine is on the drivers side .what would you use for the power steering
Bri guy
845
225
I just received that item in the mail today. Im very impressed with the material and how it is made. Very nice aluminum and the bolts seem heavy duty. Probly put it on tomorrow if the weather is nicer than today.
Bri guy
845
225
Its gonna be the shiniest pc on the motor 😂 would be a shame to paint it 😞
