Can't figure out loose steering.
Steve Bakken
Feb 20, 2015
83
8
Had my '79 Cutlass since 1989. Over the years the steering has progressively gotten looser. Replaced the mushy rag joint, replaced all the steering linkage, and finally the steering gear itself with a Napa remanned unit. Had our mechanic check the alignment to make sure the caster wasn't off. Everything is within spec but there is still a LOT of slop in the steering wheel. Suspected a bad steering gear, so I even pulled it back out and Napa was good enough to let me exchange it for a second one. I have tightened the gear mesh on the Allen bolt to the point where it gets darty. Any thoughts on where to go from here?
565bbchevy
9,591
12,612
Michigan
ELCAM
1,116
1,254
Make sure the pinch bolt where the steering linkage goes to the steering column is tight.
565bbchevy
9,591
12,612
Michigan
Streetbu
Know it all, that doesn't
3,721
11,525
Central NY
Remanufactured gear boxes are notorious for being loose and worn out. The rebuilds only make them look nice, and not leak. They do not replace the hard parts. You can only tighten up the lash so much until exactly what you had happen, happens.
If everything else checks out, my bet is it's still the gear box.
Reactions: 10 users
-dw-
205
376
Central MN
Does ur Olds have a 605 or 800 steering box? If it the 605 it may never feel tight.
