Hi, All!
I have an '84 Caprice with a 305, electronic quadrajet carb.
I live in California, if that makes a difference for emission controls.
The first photo below is the EGR valve. In all of my searching, I've not seen any replacement EGR valve
that looks like this--with two vacuum ports. Is this OEM for the car? As can be seen in the second
photo, there's a hex screw that apparently holds the EGR Valve onto the base.
When I removed the hose from what I think is the exhaust gas recirculation solenoid valve that connects
to the EGR Valve (see engine photo), a little carbon came out of the hose. I've been trying to find a replacement
EGR solenoid, figuring that it might be full of carbon, but I can't find the part.
I did discover that the hose that connects to the side tube of the EGR Valve was poorly fitting, surely
causing a vacuum leak--likely all of the hoses need to be replaced!
With the EGR Valve off the engine, I'm taking it to a mechanic to use a hand vacuum pump on
it to see if the diaphragm is still good.
I'll likely replace the EGR Valve anyway, which brand is recommended?
Thank you for the help!
Bye,
Daniel
Bye,
Daniel
