what does it take to swap a 8.5 caprice rearend to a G-body...
- i know the 8.5 is wider than my original maybe 2" to 3" inches ((but i could use the backspacing for wider wheels)) Anyways i was using my camaros 17x10.5 wheels with 2" spacers on the rear
- i know the caprice bolt patern is 5x5 and my monte is 5x4.75 ((but i can use wheel adapters/spacers))
- i know the shock mounts will have to need to be moved to the back of the housing
- can i use the stock upper and lower control arms? (( i might get away by using this on the lower ones
http://www.currieenterprises.com/CE-7012G ))
.... HAS ANY ONE DONE THIS SWAP BEFORE... WHAT ELSE IS DIFFERENT THAT WILL NEED MODIFICATIOND....
