These cars are 34-43 years old. On most 34-43 year olds the fronts start to sag over time... it's a fact of life. (Get married, you'll see...)Check the balljoints & bushings too. Even the mounting points. Could even be a bad arm.
my wife says I don't listen to her - or something like that....These cars are 34-43 years old. On most 34-43 year olds the fronts start to sag over time... it's a fact of life. (Get married, you'll see...)
On a more serious note, but lower probability, worst case could be a frame issue...
if it was the bushings wouldn't it make a noticeable "clunk" or other noise?Check the balljoints & bushings too. Even the mounting points. Could even be a bad arm.
if it was the bushings wouldn't it make a noticeable "clunk" or other noise?Coil springs and body mount bushings
It could if damaged but if worn it could be too soft to support the weight.if it was the bushings wouldn't it make a noticeable "clunk" or other noise?
The other option is that some cars, especially ones that sat unused outdoors a long time, will have the hole the bushing bolt goes through rust and enlarge, then the bushing collapses into the hole. It's wedged into place so it doesn't lift and fall making thunk noises, but it's also not at the height it ought to be.It could if damaged but if worn it could be too soft to support the weight.
