Car having trouble starting
2
I’m having trouble getting my car to start it turns over and has spark it’s a 1978 Buick limited 5.0 don’t know what it could be?
Ernest
718
958
Texas
Manually turn the throttle on the carburator back towards the firewall and look down inside... is fuel being dispensed out?
You need three things... AIR, SPARK, but no gas?
2
Yea its pumping fuel and spark someone told me it could be my timing but it was running good a couple days ago so the other day I had changed the distributor cap and coil thinking it would do something but it does the same thing nothing but turning over
airboatgreg
2,863
3,112
Don't forget squish(Technical word for compression)
airboatgreg
2,863
3,112
Buy a spark tester for HEI ignition. If it doesn't bridge that you have no spark
Ernest
718
958
Texas
If you still suspect your timing... losen the distributor hold down bolt till you can barely move it, have someone crank the engine while turning the distributor slightly in either direction to see if it will start.
bracketchev1221
1,386
1,599
Hei’s are famous for intermittent failing modules. I had one that would fail to start and then let it sit a few hours and first try start right up.
Ernest
718
958
Texas
Thats if you go for them chinesium $10.99 units.... 2weeks max working great if your lucky, then comes the butt load of trouble trying to diagnose everything and totaly dismissing the new part just because, "hey, its is brand new, that surely cant be it".(it has failed, and dont call me surely)
