So I have a bunch of questions and this might serve to answer many others questions.
So I have an ly6 for my malibu, My plan is vvt delete, ls hot cam. So now Im unsure if Im going efi or carb?
In the end but who knows when it will probably be efi one way or another. So Ive heard that for carb to run its best you should use a cam designed for carb and for Efi you should use a cam for efi? Is that true. Im asking because over the summer I was planning to start getting the motor ready for the fall. My plan is to buy the cam and that stuff now but Im not sure I should unless I have some sort of induction? Or does it not make a big enough difference and I should just get the hot cam?
Also I have a 700r4 built I was going to throw in the car but Ive acquired a few manual trans so Now Im not 100% sure which way Im gonna go. Will that have any effect on the cam I buy?
I have more questions but Ill leave it there for now.
Thanks guys
Thanks guys
