carb guys
6,826
6,728
Don't use sealer in/on a carb, ever.
10,563
14,293
but didn't replace the mixture control solenoid or the throttle position sensor.
Wait- you left them off the carb or you mean you left them alone? The float level might be correct but the float may be sinking and causing the flooding. Did you use a new float? The proper fuel level should be no where near that solenoid gasket, it should be below it. The seal is only there in case of sloshing fuel- not designed to be flooded with fuel. I think a bad float was the culprit here.
8,819
7,764
The float may be toast as said. Make sure there isn't a crack in the connector as well. Really, a Dualjet? I thought everything other than the 3.8 in G bodies were either EFI or E4M series Qjet, even in Canada in 1986.
wonderboy24
1,322
1,300
Davenport, Iowa
okay. yes i bought the complete kit the only thing it didnt come with was the mixture solenoid or the throttle sensor. i replaced everything on it.going to take it back off and see what is going on. i am not using any sealer on it.i will check and make sure my float is right. thanks for the input.
jiho
1,001
508
Qjet, see his pic in post #3.
jiho
1,001
508
wonderboy24
1,322
1,300
Davenport, Iowa
i tried again . same thing. i got a complete rebuild one online shipped to my door 218.00 . its already on the car and its up and running.
jiho
1,001
508
And that IS a Qjet.
