Carb Mixture Screws / Gas Leak
RustBucket
RustBucket
202
Houston, TX
Edelbrock 1405 Carburetor
So i rebuilt my carb for no apparent reason. Just because it was 10yrs old and very dirty. Thought rebuilding it would finish fine tuning my idle. So i used new gaskets, needles, and floaters. Everything else I re used.
My original floaters were nowhere near 7/16 - 15/16 heights so I removed them and set them aside. I adjusted the new floaters to the 7/16 - 15/16 height. Cleaned everything with degreaser and water then blew with a keyboard compressed air can (not sure if this is strong enough)
After assembly and installation, my idle mixture screws have no effect when adjusting them while the engine is on. There is also a hole on the passenger side of the carb under where the electric choke goes. This hole sucks air while engine is on and leaks gas while engine is off.
So after all this, the carb does an awkward sound from time to time (maybe every 5-10 seconds) and i can't get the mixture screws to adjust. Also the driver side jet seems to be dumping little to no gas. Does the floaters have anything to do with it? Is the vacuum sucking hole normal?
Thanks fellas.
RustBucket
RustBucket
202
Houston, TX
Ok so i determined that the hole is supposed to be plugged with a screw by googling some 1405 photos.
Now i was planning on removing the top and swapping out the floaters to my old original ones until i pulled the rod tabs and seen one of them was stuck. Not sure how it got stuck eat past the surface level. I unstuck it and the hole is not leaking gas after i shut the engine off anymore, so maybe that was causing it to flood and leak?
However, the mixture screws still have no affect while adjusting them. If i pull them completely out, the engine will idle high then die out after about 10 seconds.
If anybody can shine the light on what's going on, it would be greatly appreciated. Thanks.
Thread starter Similar threads Forum Replies Date
CrammerGrammar69 FOR SALE Roch 2bbl carb & Distributor G-Body Parts For Sale / Trade 0
Eddie Cutlass CUTLASS Replace TPS or Carb? Fuel / Air / Boost / Emissions 48
08Malibu Vortec 350 carb intake-nj Wanted 0
78GP400 FOR SALE Air Cleaner assembly, Rochester dual jet carb, silver face gauges, hubcaps, etc... G-Body Parts For Sale / Trade 3
M Need input on carb.. Fuel / Air / Boost / Emissions 11
DUBWBC New aftermarket intake manifold & carb Fuel / Air / Boost / Emissions 3
C Edelbrock carb with 200-4r Transmission Fuel / Air / Boost / Emissions 98
Bri guy Carb questions Fuel / Air / Boost / Emissions 14
lilbowtie CARB G-Body Parts For Sale / Trade 0
Red78Calais4speed 1978 manual transmission 2bbl carb G-Body Parts For Sale / Trade 0
B MONTE CARLO TBI V6 Sender in Carb V8 Tank Fuel / Air / Boost / Emissions 6
F Carb help! G-Body LS Swap 1
Froggys86 CUTLASS Carb issues Oldsmobile Cutlass / 442 / Hurst/Olds 12
Coolio MONTE CARLO Carb Fuel / Air / Boost / Emissions 6
39F Need them carb guys and opinions Engine / Swaps / Driveability 46
dickeymoore Mechanical secondary or vacuum secondary carb for daily driver Fuel / Air / Boost / Emissions 19
adrianMCmoreno Holley carb help Engine / Swaps / Driveability 1
adrianMCmoreno Any holley carb experts that can help Engine / Swaps / Driveability 20
80montecarlo Puff of white smoke from carb Fuel / Air / Boost / Emissions 4
Stupidquestionspro HELP Phenolic carb spacers Fuel / Air / Boost / Emissions 22
I CA Smog Test/Replace Electronic Quadrajet Fuel / Air / Boost / Emissions 5
bald1der Carb Swap Engine / Swaps / Driveability 10
S vacuum gauge for edelbrock carb General Discussion 3
Rudy913 Carb question General Discussion 10
Bulletproof937x Ccc to carb swap New Users 3
Stupidquestionspro HELP Throttle cable summit carb Fuel / Air / Boost / Emissions 13
7 Swapping tbi to carb 5.7 350 Fuel / Air / Boost / Emissions 4
Jorge1958 Carb issue General Discussion 15
69hurstolds Restoration Tip for transmission ID tag drive screws (rivets) Transmission / Rear End / Driveline 7
TURNA Black headlight frame screws General Discussion 6
