on mine a went from a Q-jet to holley i needed a adapter plate it came with both kinds of adapters...my hood fit barely it formed in the insulation so i took it off now it fits good i got maybe a half inch between hood and air cleaner84supreme said:ok i got an adaptor plate, will my air cleaner and everything fit and the hood shut with that adaptor in there? and is there anything i need to change on the car since im going from the rochester to the holley?
houndin101 said:this is the adapter
doesnt hurt flow at all and if you change from a qjet you have to get an adapterjoe_padavano said:houndin101 said:this is the adapter
Wow! That photo is the perfect example of why you want to get the correct intake. The sideways holes that neck down to the small primary barrels can't be doing a lot for flow. Why spend the money on a Holley just to run this "restrictor plate"?
