Adjusted both floaters at 7/16" as specified in the owners manual... I also adjusted the drop to 1" as specified in the manual...Floater float measurements... Drivers side is too low... View attachment 184264 View attachment 184265
So leave off the double gasket setup that was originally there, and just use the single base gasket on the intake manifold ? Or is a base gasket thicker than this ?The gasket is what you expect, a seal. Purpose of the spacer is to add distance from the I take and lessen heat absorption, which, on SOME engine builds that run hot in high heat summer temps could experience fuel bowl boil, etc.
Some guys double gaskets to get extra distance. Some guys double gaskets because surfaces become warped. Problem is, you can leak between the layers.
Problem with running a spacer is you can run into height problems with air cleaner and/or carb stud hitting the hood, need a drop style air cleaner, etc. Guys read about someone using one in their car and don't understand its not a one size fits all situation.
Thats all so you understand the theories behind the short and to the point answer above.
A carb base gasket itself is cheap if you didn't wind up with one. I just reloaded on some Rochester ones around $0.17-24 closeout for a variety of the mono, dual, and quadra jetted carbs.
The website shows this gasket as the base gasket... I have something similar to that but the inside isn't cut into an even rounded square...Seems like aftermarket carbs come with a thin gasket like that. Just to make sure everything is working use it for now.
Deciding which jets and rods I should use... View attachment 184294
The calibration kit I have, came with :
2 Metering Rods for the following
sizes - .070*.037, .073*.042, 073*.047
2 Metering Jets for the following sizes - 95,
98, 101
I'm shooting good horsepower and good fuel efficiency, or a good balance of the two...
Trying to see if I understand the question.... do you mean on the right side run one primary rod size, and on the left run another?Out of curiosity and a better understanding, can you mix the sizes of the primary rods and step up springs... like run two different sizes at the same time instead of running the exact same size rods and springs ?
