The taller the tire, the higher the effective final drive ratio. With a 2.29 rear gear and 22" wheels it is insanely high geared. What is your tire size?
Here is a good tire height calculator I like to use:
http://www.wallaceracing.com/tire-aspect-calc.php
Then I plug the tire height into this rpm calculator:
http://www.csgnetwork.com/multirpmcalc.html
Use the bottom (third) section of that page that includes an option for the transmission final gear ratio (1:1 for you since it isn't an overdrive).
I like to shoot for about 2600 RPM at 85 mph on the highway. That's with an overdrive. Obviously you don't have an overdrive. Do you drive your car on the freeway much?
I took a blind stab at it and assumed a 29" tall tire and put 3.08 for the rear axle ratio and came up with 3,033 rpm at 85 mph. That's revving a bit much for me but it is 85. You want to balance around town performance (lower gear feels better) with highway cruise rpm (lower gear makes engine rev higher). With that tall of a tire I would at least want a 3.08 but it really depends on where and how you drive your car. If you don't get on the freeway at all then I would put an even lower gear in it like 3.73 or 4.10.
