Carburetor question
Rudy913
646
68
New Orleans
Okay I’m thinking about changing my accelerator pump in my 4 barrel carb.
This will be my first time changing and I read that ethanol gas mess it up pretty quick which I didn’t know better. My car is constantly bogging still only at city speed. On the highway it runs smooth. Can someone show me the steps I need to take to change it . It’s a quadrajet auto line carb
JD1964
374
506
Have you checked your vacuum advance unit on your distributor? A failed vacuum advance can cause sluggish low speed performance. Also, make sure the initial timing setting is correct and the mechanical advance is working too.
blk7gxn
1,390
1,886
Best video I have found for detailed disassembly ...its for the TPS but your right there to change the accelerator pump, can use this video.
Clone TIE Pilot
3,829
2,565
Galaxy far far away
Use a putty knife to keep the TPS plunger depressed while putting the airhorn back on. Once the airhorn is back on, just slip the putty knife out.
