Champion Radiator
MechMan
MechMan
260
Long Island NY
I have seen sevral post about people running a Chammpion radiator in their G Body. It looks like it will work with what I am looking to do but I have some questions. I will be swapping a LS3 into a 4th Gen Monte SS and was wondering how to choose the outlets on the radiator and I see a lot of talk about 2 row vs 3 row. I do not see a 2 row available for the Monte of the years I am looking to work with. I looked at LS swap radiators, should I look at universal fit?
8
81cutlass
2,058
Western MN
Only issue with the champion rad especially if you are doing an LS3 is they have the inlets on the left and outlet on the right. This can make running the upper rad hose a problem and it gets long and snakey. I am not aware of a dual pass inlets on the same side champion rad.
I ran single pass on my 6.0 GP for a few years and swapped to a dual pass with inlet and outlet on the passenger side and it cleaned the engine bay up a lot.
Something to consider.
MechMan
MechMan
260
Long Island NY
I was looking at the dual pass LS conversion one for the Monte and looks like that would be a great fit. It has the inlet and outlet on the passanger side and the steam port already there. I have just heard a lot aout a 2 row is better than a 3 row so I wasn't too sure.
Texas82GP
Texas82GP
5,367
Spring, Texas
Check out the radiator Scott (injectedcutty) bought for his Cutlass. It's the same radiator we have in my brother's car. Scott even found an alternate source for the inlet and outlet fittings at a much better price, for the exact same part. Start at post 1010.
https://gbodyforum.com/threads/87-cuttlass-efi-build-6-6-19-shaft.57506/page-101
I recommend the straight water outlet like this, which makes lower hose fitment easier.....
Texas82GP
Texas82GP
5,367
Spring, Texas
That's the model I was looking at. It looks really good.
Lifetime warranty too. We had a Griffin in the Camaro but it failed at like 4k pampered miles. No warranty. The Champion has no trouble cooling the L96 in the Camaro, in Houston, running the A/C.
MechMan
MechMan
260
Long Island NY
Nice, Can't beat a lifetime warranty. Looks like it's the way to go.
MechMan
MechMan
260
Long Island NY
What about the electric fans. what does everyone run or plan to run?
