MONTE CARLO Champion radiators
M
M&M
n00b
Sep 13, 2019
4
Hello all, My name is Marc I am from Calgary Alberta Canada, and I have been working on my 87 Monte for 8 yrs. Was curious if anybody knows about these Champion radiators, as I have noticed in the past that they say they fit but they end up being a universal that really does not fit. I am new to this computer stuff.
565bbchevy
565bbchevy
7,252
Michigan
I have one in my 86' Regal with a 355 SBC and it fits well with the 307 shroud, the only thing I had to change was going to larger hoses since the radiator has a bigger inlet and outlet than the factory radiator.
You will find a lot of people on here are running a Champion.
Injectedcutty
Injectedcutty
5,029
Louisville, KY
Mark, welcome to the forum. There are a few guys on here from Calgary.
I'm one of the other guys with a Champion. I'm running an LS swap unit, the fit and finish is great for the price! My only complaints are the drain petcock location, and on the LS swap the lower outlet comes straight out and makes the hose super close to the frame.
M
M&M
n00b
Sep 13, 2019
4
I'm one of the other guys with a Champion. I'm running an LS swap unit, the fit and finish is great for the price! My only complaints are the drain petcock location, and on the LS swap the lower outlet comes straight out and makes the hose super close to the frame. View attachment 126829
Reactions: Injectedcutty
M
M&M
n00b
Sep 13, 2019
4
That looks awesome the thing is just changed all my hoses, maybe will try dual fan on the set up that I have know.
sent some pics maybe it worked like I said not to good on these computers.
Thanks.
Marc
565bbchevy
565bbchevy
7,252
Michigan
If the cooling capacity is not in your current radiator fans can only do so much.
565bbchevy
565bbchevy
7,252
Michigan
we have our fan blowing away from the engine. should we reverse to blow towards the engine?
If the electric fan is on the front of the radiator it needs to be a pusher and force air through the radiator towards the engine, if it is mounted on the engine side it needs to be a puller to pull the air through the radiator towards the engine. no fan set up should move air away from the engine.
Reactions: lilbowtie
Thread starter Similar threads Forum Replies Date
84cutspreme Cooling / Heating / AC 12
MechMan G-Body LS Swap 18
RegalChris1986 Interior 8
