Change angle of window?
MrSony
MrSony
5,542
Des Moines, Iowa
What screws let me tip the window in or out? I replaced my outer sweep and tightwned the felts up to the glass and it was fine for a while. Now it seems to like to catch on the blow out clip. The window doesn't follow the curvature of the pillar, it rests on the inside of the clip between it and the door seal. Is that right? Any input is appreciated.
MrSony
MrSony
5,542
Des Moines, Iowa
Anyone with "perfect" windows got any pics of how they're aligned compared to the seals?
MrSony
MrSony
5,542
Des Moines, Iowa
The bottom of the window is in the middle of the door seal and the top tapers off to the outside, if that makes sense.
One More Pontiac...
One More Pontiac...
23
13
CT
Just fixed the same issue on the left door of my GP with a big washer...the sheet metal had snapped at the vertical guide lower bolt hole.
Reactions: fleming442
MrSony
MrSony
5,542
Des Moines, Iowa
According to this guy at the 6:33 mark, that piece will change the angle of the window... which is what I'm after. Hopefully I'll get to it this weekend, I'll report back. His are power windows, I hope my car has the same setup.
Thread starter Similar threads Forum Replies Date
Tyler l Front clip change General Discussion 1
Doug213xrj Cam Change gaskets whats the difference ? General Discussion 1
T 85 El Camino basic to fill gauge change over General Discussion 2
GBody.co.uk CUTLASS Change THM350 Oil Cooler Lines Transmission / Rear End / Driveline 5
Caper Dash change out Interior 4
Jeff Blagden time to change stuff General Discussion 11
565bbchevy Unbelievable oil change General Discussion 6
B Radio interference after cap & rotor change Electrical / Ignition / Starting 9
pontiacgp How Long Does it Take You to Change Tires... General Discussion 14
CaliWagon83 Change of heart for powertrain: Thinking aluminum head 9.5:1 4.1 EFI V-6 Wagons! 48
Buick_82 Torque value angle degree? Engine / Swaps / Driveability 32
P 4 door/wagon driver side rear outer window sweep Wanted 4
WanaBa442 Window sweeps? Oldsmobile Cutlass / 442 / Hurst/Olds 7
bazthespazz Rear window for 1984 El Camino Wanted 0
Kennyjoe28 NEED! 83-87 regal rear window hard top trim Wanted 9
J Window switch bezel General Discussion 1
RideOrDieRegal84 Power window failure Electrical / Ignition / Starting 12
DROLDS84 Window Sweeps Oldsmobile Cutlass / 442 / Hurst/Olds 16
P Window sticker help Chevrolet El Camino / GMC Caballero 10
M Rear Window Handle Wagons! 1
8 G-body door window belt molding G-Body Parts For Sale / Trade 0
CleanCutty86 Window stops Body / Trim / Paint / Glass 3
Dave_logan14 81 El Camino rear window (tinted) G-Body Parts For Sale / Trade 5
J Power window switch wiring Electrical / Ignition / Starting 2
blackbuck350 81 malibu wagon rear window weather seal General Discussion 19
SSpev Power Window motor Electrical / Ignition / Starting 3
Thelittlecutlassthatcould Broken rear window Body / Trim / Paint / Glass 4
69hurstolds CUTLASS Power Window wiring diagram adding relays to speed up the window motors How-To's / Knowledge Base 33
4 86 442 Rear Window Lower Trim Clip???????????? Body / Trim / Paint / Glass 6
yaahoos Drivers side power window n/w Interior 3
565bbchevy Jumping power window switch Electrical / Ignition / Starting 4
HAFROD Rear window interchange years Body / Trim / Paint / Glass 17
pontiacgp Power Window Switch General Discussion 14
85ss/85gn Rear side exterior window trim Wagons! 13
Grnmnstr Rear window, lower garnish molding clips General Discussion 19
Drkuhar Inner window weatherstrip mounting question Interior 4
CaliWagon83 REGAL Power Window Regulators - Same or different between coupe and wagons/sedans? Body / Trim / Paint / Glass 3
P Buicks & Coffee with a Window Racer Install w/ Before and After results Video General Discussion 0
Hubb79 Window sweeps Interior 0
D Setting window in weather striping on driver door is there anyone who does ajustments New Users 1
T 87 El Camino window adjust Body / Trim / Paint / Glass 0
GBody.co.uk Spring Loaded Power Window Regulator Refit Body / Trim / Paint / Glass 9
Tomeal El Camino quarter window seals Body / Trim / Paint / Glass 0
P Rear window to trunk piece General Discussion 7
1bad79 Gm window cranks Body / Trim / Paint / Glass 1
Similar threads
