it's not hard but if your asking I take it you havn't done one before. If the pinion was set up on another rear end then the shim for the depth of the pinion will most likely be good. You should use a new crush sleeve tho after you have checked the depth of the pinion. Keep the backlash shims in place when you take out the carrier and before you take off the carrier caps mark them so they go back the same way. Once you reinstalled everything and have proper backlash, it needs to be .006 to .010, and torqued the caps check the depth of the pinion. If it's goo then you can remove everything to install the crush sleeve. To crush the sleeve you turn the pinion nut to 300-400 ft-lbs for the initial crushing until preload is within spec. You'll need to get your proper rotating torque after you have crushed the sleeve, the torque is supposed to be 24 to 32 inch lbs. After I crush the sleeve I have backed off the pinion nut in some cases to get the proper preload on the pinion bearings, that's what the crush sleeve does.
