Changed instrument panel lights, gauges not working
Call Her Bu
108
37
Arlington, TX
So I swapped out my gauge cluster bulbs for led lights and when I put it all back together, my gauges didn’t work except for the speedo. I made sure everything was back the way it was. So I think I did at least. Is there Something I should check for?
My signal lights in the gauge cluster don’t work either but they were like that before I changed bulbs. I bought a new flasher and still same result. Any other ideas?
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
Sometimes the LED bulbs are polarity sensitive. Turn the key over to charge the system and install bulbs to make sure they're lighting up before you assemble everything.
g0thiac
939
582
So what gauges don't work? If you installed LED's instead of regular bulbs, chances are you didn't wire something correctly, or install them with the polarity properly.
First, check to see if a fuse got f**ked. If that's good, use a multi meter and check around for voltage with the key off, and on.
My Pontiac didn't have working dash lights when I bought it, because the idiots who wired it before me did a LED dome light mod, so I added an LED strip, and wired it to a 12V source in the car.
Call Her Bu
108
37
Arlington, TX
Tach, oil, fuel, temp and volts don’t work. They all did before. I’m going to disassemble and reconnect everything with the key forward.
fly_25
136
67
Sometimes it's hard to get a good connection on the printed circuit board and the plug that plugs in to the dash. If it's not seated right then you'll get some dash problems. I've tried bending the tabs a bit on the plugs which helps a bit, I've also added some foam tape under the printed circuit board where is meets the plug to kinda "prop up" the connection and push it against the plug more
Call Her Bu
108
37
Arlington, TX
That could be it. I’ll take it off and make sure it makes good connection. Thanks!
fly_25
136
67
No problem! I always find that connector to be tricky to get right.
Call Her Bu
108
37
Arlington, TX
Ok so I put the regular bulbs back in and now they don’t turn on. Below is what happens with the car turned on.
Pic 1- gauges work when the headlight switch is off.
Pic 2- gauges go crazy or off when I turn on the headlight switch
Pic 3- when I turn the headlight switch while it’s on and turned all the way to the right, the halfway work?
Call Her Bu
108
37
Arlington, TX
With the key just turned forward, car not running.
Pic 1- headlight switch off
Pic 2- headlight switch on
HELP!!!!
