My 1986 Cutlass won't accelerate past 20-30 miles MPH.
Damn. It's always had a slight vaccuum leak, but the car is really slow now after changing the tank. A fueline had a bad leak and I drove to the store while it was leaking, dropped the tank again and replaced the rubber hose from the sending unit, the hard line from the rubber hose and then the other rubber hose going into the other hard line.
No more leak.
But it's still spuddering like it was when it was leaking but slightly improved the problem.
Did I simply just put the house clamps on too tight? Is that even possible?
I put some old gas mixed with fresh gas in my tank to get her running... Is it bad gas??
I put some 89 gas in my tank, along with Octane booster, I can tell she wants to TAKE OFF because Lshe will JUMP FORWARD for 1 second then go back to mediocre *ss speed.
I just did a tune up a couple months ago.
Also the car is REEKING of gas as you drive and makes you dizzy behind the wheel.
What is the cause of this, possibly???
No more leak.
