Chassis Stiffening
rubio9800
242
110
California
Hello everyone,
Looking to do some chassis upgrades and can see tons of different style of braces were on g body’s. any idea where to get some?
so far doing a rear sway bar
81 Grand Prix
thanks
-dw-
209
377
Central MN
Solid body mounts will firm it up a bit.
Kiko
298
339
Ottawa, Canada
It depends how stiff you want your ride to be. Will you be dragging? cruising? slalom? That would be where I'd start -- define the reason for your ride and go from there. Solid body mounts are great, but there are drawbacks as well. It all depends on your answers to the questions. You'll probably get more meaningful responses once you tell us your ride vision.
rubio9800
242
110
California
just cruising
Kiko
298
339
Ottawa, Canada
If it's just for cruising, then you don't need to stiffen the car with solid mounts. I'd replace the old, worn out mounts with brand new rubber. You might be tempted to go the poly route, but I found that it's not really required. A nice rear stabilizing bar and one up front will certainly help. Do a search on this site and you'll find plenty of examples. There are some great builds that you can follow -- very inspiring and educational.
Good luck with your ride and have fun!
rubio9800
242
110
California
thank you for the advice
