I'd like to swap the 7.5 rear for an 8.8 in my 87 monte ss. What is the easiest/lowest cost method to accomplish the job? I'm ok with dealing with the Ford bolt pattern and stock gears (I do want to find a factory posi rear).
should I get a Fox body rear or 94-98 rear?......I understand the Fox rear is 4 lug/drum brakes.....while the 94-98 is wider than the gbody...which is the better trade-off?
I see many are using the quick chassis kit:
http://www.trickchassis.com/index.p...swap-instant-center-correction-kit&Itemid=320
What is required to be purchased in addition to the kit? I believe that mustang adjustable uppers.....and gbody lowers will work.....what else?
