I'm wanting to go ahead and add replacement springs that will keep me at my current ride height in the front of my el camino
Moog 5600,5602 and 5608 are listed as stock replacement springs
Free standing lengths vary but installed height appear to be listed all the same at 11 inches
I have been advised to use the 5660 spring. I see it's a common swap but I'm seeing people are cutting 1/4 cool off of them
Moog lists the install height as 10.75 inches
So if my math and thought process are correct. The 5660 should give me the same or about .250 lower ride height in the front
If this is correct I'll be happy with that. I'm currently lowered using a drop spindle and I do not wish to change that
I assuming that people are cutting the 1/4 coil just to obtain a desired ride height correct and in my application it wouldn't need it
Thanks for clarifying this for me
