85GPLef41 said:pontiacgp said:they look good so go throw those bushings in the freezer for a couple of days and if you can stick the control arms in the oven for a while to heat them up just before you install the bushings.....they'll will slide in easily if you do
Thanks for the tip! i Wouldn't have thought of that..would that work for the upper and lowers?
pontiacgp said:85GPLef41 said:pontiacgp said:they look good so go throw those bushings in the freezer for a couple of days and if you can stick the control arms in the oven for a while to heat them up just before you install the bushings.....they'll will slide in easily if you do
it would work for both and the rear trailing arms ...I'd put some antiseize in the holes before I slid the bushings in...
